  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
The Pig Drawing Personality Test
The best part about this is that you can forward it round your office and then laugh at everyones crap drawings. We are thinking about setting up a small pig art gallery in the corner of the office here.
Don't cheat by reading the whole thing first. It is hysterical if you do it right!
Get a blank piece of paper , draw a picture of a whole pig on it, not just the head , just a basic drawing though , don't spend too long on it .
DRAW THE PIG BEFORE YOU GO ON.
IF YOU DON'T THE TEST WILL NOT WORK!!
NO CHEATING,
DRAW THE PIG FIRST
HAVE YOU DONE THE DRAWING??
IF NOT, DO IT NOW
IT IS REALLY FUNNY IF YOU DO IT RIGHT!
OK' NOW TO THE INTERESTING STUFF.........
The pig serves as a useful test of the personality traits
of the drawer.
· If the pig is drawn to the top of the paper , you are positive and optimistic.
Toward the middle , you are realistic.
Toward the bottom, you are pessimistic , and have a tendency to behave negatively .
· Facing left, you believe in tradition, are friendly, and remember dates(birthdays, etc.)
Facing right , you are innovative and active , but don't have a strong sense of family , nor do you always remember dates .
Facing front (looking at you ), you are direct, enjoy playing devil's advocate and neither fear nor avoid discussions .
· With lots of details , you are analytical, cautious , and distrustful.
With few details, you are emotional and naive , you care little for details and are a risk taker .
· With less than 4 legs showing , you are insecure or are living through a period of major change .
With 4 legs showing , you are secure, stubborn, and stick to your ideals
If you have drawn more than 4 legs , you are stupid .
· The size of the ears indicates how good a listener you are. The bigger the better.
· The length of the tail indicates the quality of your sex life, and once again the longer ,the better.
Ok, who didn't draw a tail?
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
