  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Miles aka 'GOT RICE' work at Rocky road at hay st and barrack st...
They have nice exotic chochos... :P
I think its very addictive stuff. it should have warning... like
"Cosumer Warnning, Eating this chocholate will make you less attractive to opposite sex"
"Please loose double chin b4 consuming this product" :D
Originally posted by Jon R33
ooooo sounds nasty skyzer, my advice would be to read up on how to hack the proxy server and by pass it, or use someone elses logon :D of course if your the only one there on nite shift then it might be a little hard to deny.
they know that trick grrrrrrrrrrr
and the browser inside a url trick grrrrrrrrrr
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
