  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Boostzor
And there u stand, little son of rajab fuantleroy, surrounded by the maladjusted, ever try wearing a bonnet? u should.:bahaha:
lol no reason to tell it like it is :D
hrmmmm bonnet. nah it doesnt set my eyes off :P (unless its carbon fibre :) )
Psiker
(and yes i know what bonnet u mean :( )
Psiker
Nah i dont play online. I have to be able to alt tab out. I am at work after all.
Hey how about 4NIC8 on an old hq wagon
can still alt tab just the same online :D. if u played online i could help ya finish the whole game in half an hour :) all the way thru hell
Psiker
I still gotta build up some levels and that takes time. Remember the good ol days where u could copy items with that little bug
yah back in d1 days. there are alot of hacks out for d2 now. not so many when i started playing :D but its all goodpretty much what i wouold do online is rush u all the way thru hell then do cow hell games with u :) so u gain heaps of exp very fast. ppl mainly only play online to pk or magic find now. its good casue ppl cant take ur items when they pk you
Psiker
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
