  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
What you talkin bout Willis?
Joe - don't worry about the money until I give you the DVD player.
Shuto - call me a wuss but I don't bother racing cos I don't wanna risk breaking something on a 400m straight bit of road - kinda not what my car is meant for.
Bussiness is bussiness... I just want to make sure that :) cool Thanks Micko :)
True... GTR isnt for straight road... Its for turning tight corners...:) yes drifting...
What's point having 11 sec car if you cant even go to deli to pick up Milk! :D
Originally posted by macka
Kenny u have a way with words....]
U must of swept your misses off her feet with similar sweet nothings
cheers
mac :D
Awwww you glib tongued c*nt you.
Is that the sort of words you mean?:)
Cheers
engrish mahster
Ken
yea , specially cos Milk is in the eastern states.
Cheers
Ken
Originally posted by skyzerr33
she saw u the other day
and another gunmetal R32 GTR the day b4 that
Yep , gunmetal grey GTR's are like bums
everyone has got one.:D
Hell , I've had three
Cheers
Ken
Originally posted by gtrken
Joe , joe  , joe. You don't absorb much do you ?
R33 GTR's will not be avaliable for compliance for some time as no one has the plates for them yet due to the rule change on May 7TH
Cheers
Ken
damm it! ohh well I have other things absorb such as how TCA cycle or kerb cycle in glyconeogenesis and glycolysis.
this is where you comes in :D you are the expert so I ask you :) hehehe :)
cheers
Joe
oh and macka u was 100% correct with the +ve wire on the cig lighter cheers :)
hooked the ground up ontop of the gear box :)
Gee , and we all thought he was TOTALLY useless.:D
Cheers
Ken
cheers
Joe
WHAT !! ??
on glyconeoene... , glyconeegee... , gliko.. ahh ****
I can't even say it:D
Cheers
Ken
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
