  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Adrian_perth
neo, i think u are talking bout the gmax rims i am gettin coz it's a 5 twin spoke design, can't remember if it was deep dish, but i do want deep dish!
adrian :P
Just make sure you speak to the dude i have in mind. He gives good deals and if he has the ones on the shelf still it would be great.
ken, what turbos did u get?
adrian :P
Nismo 581's.
Bolt on fit , legal for the class of competition I do and 320hp ea at 1.5 bar. bout the same as 2530's but a bit laggier cos there non ballbearing
cheers
Ken
Originally posted by GTS-t VSPEC
Aidwin,
Don't be a p u s s y  like Joe:p
Ken, Big plans?
See'ya:burnout:
slowly , slowly.
Or until the blow by on the current engine gets worser , worsest, more worser, ahh badder...
cheers
Ken
Originally posted by 33Spec2
yeah i did you musta missed it! well 4 all those who missed it and wanna cum visit it is 76 MEADOWBROOK DR. PARKWOOD WA 6147 AUSTRALIA
by the way write it down coz im deleting this post!:P
No pen , ahh well , who cares.
Delete away adrian....:P
cheers
Ken
Neo,
I prefer 5 spoke design:D
Ken, My rev limit is 7500, but with engine braking I hit 8200, whoops:D
See'ya:burnout:
Revlimiter will not stop an over rev on downshift.
Ask Steve SST what that does to GTR engines ( aka wholagan )
Cheers
Ken
