  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Ken I have tried being a bitch... I kicked his sister out of our house, I told his mum that I didn't care she was divorcing andrews dad and to stop telling me about it.... but then andrew gets all shitty at me hahahaha So now I just act like I'm deaf and I don't know how to talk
Ohh well , read previous post.
ie. Get pissed
What's he gonna do , divorce you ???
Cheers
Ken
Originally posted by SHUTO-BOY
Agree with Ken, pls don get hair extensions Niz
ooooohhhh aren't you the quiet one.
Everybody knows I'm just an old pervert.
Didn't know that you were one too .:)
Cheers
Ken
haha a good family fight always makes life interesting - imagine how boring it would be if you were all like this :grouphug: singing koombyaaa and drinking hot choclate
talking about all things hot chocolate - we didnt get to play fluffy bunny with pauls marshmellows last night hahaha
Originally posted by skyzerr33
so where are all the pics of drunk ppls from mickos?
No pics , WAAAAAY to incriminating.
Have you rung Kyles to see if she's surfaced ?
I don't want to cos she might think I'm stalking her. * insert evil laugh *
Cheers
Ken
Liz: i saw this claire danes movie a while ago,and it was like that
Niz:but ur hair looks fine
ken:no im not a perve
Ahh but thatr's what they all say.:)
Cheers
Ken
fluffy bunny with pauls marshmallow ??
where is this convo going Niz.
Surprised you weren't getting tapped on the head by the excited pwpt60secf last night. Oooohh , that's below the belt.
Bwahahaha
Cheers
Ken
aidwin - i cant believe he had to carry a carton of beer for you!! Also never known someone to spend so long in a grog shop making up their mind and ringing other people for their opinion haha
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
