  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i have three choices of EBC HKS EVC 5, Greddy Profec B Spec or Blitz Dual SBC spec s
evc5:- cool coz it has a lil screen lol
profec b spec:- nice and simple heard good things but also heard hard to tune?
blitz dual SBC spec s:- heard holds boost good but looks boring :)
adrian :)
People... if you missed today on church then make sure go to on sunday session at least :)
Our father in heaven. halowed be your name.
your kindon come, your will be done, on earth as in heaven..
Give us today our daily bread/rice.
forgive our sins as we forgive those who sin against us.
save us from trial and deliver us from evil.
for the kindom, the power and the glory are yours not an forever amen.:)
