  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yuk kyles! Its horrible when u get to the point where theres nothing left in ya stomach but ya keep reaching anyway.
I had my ex tell me to go get a coke haha as soon as i started thinking about coke i rushed to the toilet again haha
Im pretty lucky - it takes a lot for me to get to the chucking point. 3 bottles of wine made me passout - i didnt even realise i drank that much - i still dont believe i drank that much - i wouldnt be surprised if the boss spiked it but i got no proof.
yeah i called mum this morning and she said the best thing for a hang over is coke and greasy food like a hamburger.. I was just about to throw up at the thought of it. The grease soaks up all the alcohole. Troy did go to maccas for me on the way here and asked me what i wanted... Eiw yuck. I just had some apple then and ill try eat somthing else later.
this is the first time ive had alcohol posioning
I didnt really have that much to drink last ngiht aswell.. Ive drunk way way way more than this. One night in northbridge Troy and I and 2 other friends we had heaps to drink.. I had 15 burbons and then we got stuck into the shooters and shakers.. would have had about 10 of thoes! And i was fine. A little shaky in the legs but otherwise fine
    • Man, I hope this one gets finished  i just randomly remembered it the other day and thought I’d check in.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
