  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i would liek to see the surprise chef do something with the stuff in our fridge at the moment - i think he would probably resort to going outside and making mud cakes!! we got F-All! My mum usually gets me all the stuff i like and puts in the fridge before she goes away :)
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
