  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
hey jason.
Err.. i made this really yummy dinner for Troy and I and i could only eat 1/2 of it :D still havent got my appatite back from thursday night. Troy was happy but he stole what i didnt eat!
That is the way it should always be kyles. Good girl. Troy might keep you sick from now on.
I think Joe will blush alot tonight!!!
yeah I did 1st time I went there with my friends like when I was 17 hahahah... I did know where to look hahhaha :D
and had huge bonner all night (oopps too much info)....
anyway I'll be meeting up with my girlies from uni too :(
