  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
hey jason.
Err.. i made this really yummy dinner for Troy and I and i could only eat 1/2 of it :D still havent got my appatite back from thursday night. Troy was happy but he stole what i didnt eat!
That is the way it should always be kyles. Good girl. Troy might keep you sick from now on.
I think Joe will blush alot tonight!!!
yeah I did 1st time I went there with my friends like when I was 17 hahahah... I did know where to look hahhaha :D
and had huge bonner all night (oopps too much info)....
anyway I'll be meeting up with my girlies from uni too :(
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
