  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey guys... hows things? malaysia is hot!! temp wise that is.. hehe.. wish i had my car here - could have soooo much fun in this traffic.... :P
anyone know where the brother's car place is? i know there's a chain of them but riaz (no_respect) told me of the main one which is a mix of rice heaven and good cheap performance parts...
