  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yup half the bottle :) bourbon is my drink :P
will have to try and find a bottle of gold label beam for u ladz to try sometime.
bucket don't know what ur talking about.
i was feeling ill spent about 40min expecting to chuck but didn't
kylies was just trying to cause trouble
Originally posted by skyzerr33
yup half the bottle :) bourbon is my drink :)
Just remember us Asians dont have genes tolerates the high level of alchol concentration in the blood.
that's why if high alcohle concentration is detected in blood... goes into fail safe mode... :spew: and black out ;)
hahahhahaha :D
Originally posted by Nizmo
yeah haha kylie said u were more talkative than normal. But it didnt seem u were drunk by any means
Im never touching this rare breed stuff after seeing its victims!
You can talk hahhahahaha.....
giggle giggle giggle giggle giggle giggle giggle gigglegigglegigglegigglegigglegigglegigglegiggle.........
hehhe :D
well that CC is pretty bad stuff too...
paul went to mackas didnt stay long.
i can tolerate not a bad ammount for a girl my friends seem to get drunker on less than i do - but then again ive been drinking for a very long time :D my dad used to make me shandies (beer mixed with lemonade) and bring them into me when i was playing barbies when i was a little tike haha everytime i saw a beer bottle i would demand a shandy hehe
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
