  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
The Corolla pings, you wanna tell me how to stop that now!
Don't care anyway, it made it tyo Albany and back on Friday so if it blows up I don't care, put a new motor in it!
Are you all talking about Adam's car pinging on the dyno the other day?
Paul has had his rage problems all his life!
adam,
if you don't have larger injectors or if you haven't increased the fuel pressure via rising rate reg then you can expect problems at power levels you are reaching. you may find that one piston is responsable for the ping as well, due to a partially blocked injector or something.
Here's one more idea to try:
Run a set of 7's plugs if your not already.
