1. Intelligence.
2. Sense of humor.
3. Passion
4. Consideration
5. Honesty
6. Flexibility
7. Serenity
8. Balance
9. Ambition
10. Attentiveness
^ obviously not written by me cos all that = a gay guy!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
1. Intelligence.
2. Sense of humor.
3. Passion
4. Consideration
5. Honesty
6. Flexibility
7. Serenity
8. Balance
9. Ambition
10. Attentiveness
where is looks..???
yeah i was thinking wheres the butt and eyes and smile - maybe im just shallow!! but serenity? sounds boring - geez i dont want to go out with a monk!! I think they just took out basically everything that makes a guy interesting!! sure they should have some of those qualities but i think a guy with all of them would bore me absolutely!!
Aidwin - *sigh* it has a badge and an extra turbo and an extra $10,000 to pay for one to me - thats the only thing that sets them apart - nice car, wish i had one but its like a Holden Clubsport and a Holden GTS - look the same - different badges, different power ratios, different price tags thats it!
All that dancing must keep you fit Liz!
Niz - yeah I am fit... but I don't look it unfortunatly. irish dancing makes my legs thick... it sucks hhahaha
Drifta - the other one I have not seen.... I will see it next week. He wants about 24K for it I think... 96 series II - no mods... sounds pretty good. But I love that one at c-red...
ralph mag website probably has some - hehe utter crap but funny.
Going down is:
Just the tip of the iceberg when it comes to things you can do in bed.
A phrase heard in lifts. :P
Best when reciprocated
Hope i didnt make anyone blush - just thought it was funny.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
