  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
its Buffy night
u change your avatar as much as i do shan :P
yeah i have a bit lately... can't quite find one that i like, thats also not offensive.
luckily i "lost" all the growing up toddler photos layin around. The whole naked phase (0-25) wasn't all that magic.
haha Shan :P
Peter hellier - i dont really like him - he doesnt remind me of shannon either. Just something rather try hard about peter its a kind of like "hehe we're with rove hehehe" aghh
my car should be tuned this week or early next - fingers crossed i havent spent too much over easter and the funds are there anyway. Whenever i put my car in for anything i like my bank account of a $1000 cos it usually ends up costing me $800!!
haha Shan :P
thanks Lauren.
ya quickly learn who ya mates are around here. :P
What exactly were you getting tuned.?
Aidwin, I think it's an OS Gilken. it's a damm good clutch.
What have you had done..? front mount.?
rev's, gear changes, timing in general needs a bit of a play with - i honestly dont car what slako fiddles with as long as it stops coughing and spluttering and picks up the pace a little other than the boring old grandma pitter patting its doing now :P
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
