Oh no, it was your 2nd car, what was your 1st? A VW convertable finished in a nice shade of pink!!! (hehe!)
You want me to tell you what I have heard about you? I wouldn't go there! If you want a story on me, you won't get one, you don't know anyone I went to school with.
How is Cher anyway? (hehe!!)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by R31 Chick
Hay, I have lots of stories, don't push it or they will be on here for the world to see!
that's quite funny hey, as I went to school with my mate Psiker too... now THERE could be some incriminating stories (mostly about ex-gf's, but nevermind that)
a 1981 Ford Cortina Ghia.... yeh babay! RWD 2.0L N/A power!!
it was Red actually....and was quite fun in the wet.. hehehe
best you PM me with an embarrasing story before you post it eh?
What is Psikers real name?  My b/f and Dan and Phil probably know him to then hay!  More stories, yay, I love stories!
Still no stories on me!
Ahhhh.... you'll have to ask him yourself :)
tell me your last name and what school you went to, give me a few hours and i'll have you sussed :)
Originally posted by Strich9ine
Dam, there goes my life ambition, yeah that's right, I was planning to stalk you....
Well, you just never know, from what I heard, hmmmm. Nope, last name and what school stay a mystery!!! Oooooooo!
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
