  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
This is the transcription of the ACTUAL radio conversation
between the British and the Irish off the coast of Kerry,
October 1998. Radio conversation released by the Chief of Naval Operations 10-10-98.
IRISH: Please divert your course 15 degrees to the south to avoid a collision.
BRITISH: Recommend you divert your course 15 degrees to the north to avoid a collision.
IRISH: Negative. You will have to divert your course 15 degrees to the south to avoid a collision.
BRITISH: This is the Captain of a British Navy Ship. I say again, divert YOUR course.
IRISH: Negative. I say again, you will have to divert YOUR course.
BRITISH: THIS IS THE AIRCRAFT CARRIER HMS BRITANNIA! THE SECOND LARGEST
SHIP IN THE BRITISH ATLANTIC FLEET. WE ARE ACCOMPANIED BY THREE DESTROYERS, THREE CRUISERS AND NUMEROUS SUPPORT VESSELS. I DEMAND YOU CHANGE YOUR COURSE 15 DEGREES NORTH. I SAY AGAIN, THAT IS 15 DEGREES NORTH OR COUNTER-MEASURES WILL BE UNDERTAKEN TO ENSURE THE SAFETY OF THIS SHIP.
IRISH: We are a lighthouse................ Your Call.
The rest are too long or in powerpoint form
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
