well I drove it and I love it Ken... but I still want to see this one is Malaga.... but yes I am trying to make my decision easier hahahaha
Russ - no the series II is not cheaper.... When could you go out there?? We can meet out there or I will finish work early.. if you feel like being my kling kling bitch and picking me up from wleshpool... (which is pretty much on the way since we have to go up tonkin) hehehehe
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
you got pwpt60secf coming round tomorrow ?
Don't get him pissed and make sure he is at my place 6am Saturday.:D
cheers
Ken
Yep - looks like we're gonna have a bit of a gethering & bbq tomorrow afternoon/evening.
Regular whorers are welcome to join in but please confirm with me beforehand.
Originally posted by Sneeza
Ken - so would you pretty please  with a blow job
WOW...
Oh shit , I thought she was serious, bugger.
Yep , no prob , tell me what day.
Could check it out after work next thursday cos the boys at cred work back then.
Cheers
Ken
Originally posted by Neo
Gday Everyone
I was lost in the la la land of Taka Kaira again.
Great way to go to sleep.
Ahhh , volk te37's , advan rg's , HKS 2530's , Apexi power FC.
Bah , who needs counting sheep.
Cheers
Ken
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
