  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Thankgod it's not targa, don't feel like pulling the GTR out of a tree:p
See'ya:burnout:
There are trees at Wellington dam so don't speak too soon.
cheers
Ken
I think she's staying there too, that way we don't have to get up so early:D
See'ya:burnout:
Huh ??
If you stayed at home you would get an extra hour sleep.
Mickos is 35mins from my place and you had better be here at six
Takes 3 hrs towing and MUST be there by 9.15 at the latest.
Cheers
Ken
Ken,
Well if Frank Ferrari can roll Ray's car on a straight bit of road then anything can happen:bahaha:
See'ya:burnout:
It was straight alright, straight thru a T Junction and over a bank
Cheers
Ken
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
