  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
I think he got it right Ken - you don't think he's gonna do any work do you?
btw - I reckon I might like to drive out on Sunday for the hillclimb. How long will it take me (bearing in mind the current demerit point regime) & how will I find the dam?
down sth west hwy to collie turnoff ( just past Roelands )
Head to Collie and look for sign saying Wellington dam.
Bout 2 3/4 hrs from your place.
Cheers
Ken
Originally posted by gtrken
that's meddlesome
Ken - I beat you for once...won't get used to it though:uh-huh:
Neo - no dramas, we can go down in the same car if you like or cruise together.
Paul - this weekend will be an exception, methinks we were fortunate last time cos we didn't see any law enforcement reps:uh-huh:
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
