  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
OK Ken - give us the info on your weekend of motorsport...
Micko , thanks for the bbq and beers on Friday. Left in kinda of a hurry so my brownie credits didn't run out.
Got 4th o/r ( 0.35 secs behind 3rd ) and 1 st 4wd at Collie on Saturday.
Got 2 o/r ( don't know how close to 1st ) cos we had to go but only got 2 nd 4wd.
Got beaten by a *SOB*
rex.
Grrrrrr:mad: :) :) :):mad: :mad: :mad: :mad:
Cheers
Ken
Originally posted by SHUTO-BOY
ah dont worry Ken, youll get him back the next time :)
yep , I hope so as I can't have a rex taking out the 4wd class for the series.
Got some in car and Paul took some general external stuff at Collie and Wellington Dam today.
Got to get it transferred onto CD or Vid.
Cheers
Ken
Originally posted by caminperth
me back.. just finished the phone thing...
good work ken - pity bout the rex, but then again not much to worry about - it's only a rex.. hehehe
did you get any good footage?
Am going to look through the stuff pwpt60secfalg took and will then work out what to do with it.
Cheers
Ken
ken - great.. let me know if you're going to burn any cds.. i've got about 70 blanks sitting here not doing much.. :)
I think paul said he will try to get Neo to turn it all into something useful but thanks for the offer.
Cheers
Ken
no probs ken.. :)
aidwin - wiked.. very very interested in seeing what it's like...
me out for tonight.. tired after the plane flight and work is going to busy this week catching up.. will give u a ring tomorrow aidwin..
nite guys...
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
