  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
i think ken just kept him up late gaurding the GTR
When it's on a trailer , tied down and locked parked outside the front door , I don't think so.
Guess again .
:bonk:
Cheers
Ken
Originally posted by SHUTO-BOY
ken: yep my mate has that turbo on his rex,but he got hosed by a GTR anyway :)
Yes I could beat him at Collie circuit cos his best time is slower than mine.
He is a copper ( I believe ) , lives closish to Wellington dam and the light weight out of the slow corners on the track put me at a slight disadvantage ( aided by my inability to drive the car without drifting ) Hehehe
Cheers
Ken
paul was probably drinking all his crownies and fighting with the local folk
Nope , most of pwpt60secfalg crownies are in my fridge.
We all came back from the restaurant together.
Guess again
:sperm:
Cheers
Ken
Originally posted by Kyles
ahh so paul and niz.. 'enjoyed' themselves this weekend huh ken!
Yep , they seemed to have a good time watching the action ( on the track ).
I'm sure they will fill you in on the details later.
Bye
Ken
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
