  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
i think ken just kept him up late gaurding the GTR
When it's on a trailer , tied down and locked parked outside the front door , I don't think so.
Guess again .
:bonk:
Cheers
Ken
Originally posted by SHUTO-BOY
ken: yep my mate has that turbo on his rex,but he got hosed by a GTR anyway :)
Yes I could beat him at Collie circuit cos his best time is slower than mine.
He is a copper ( I believe ) , lives closish to Wellington dam and the light weight out of the slow corners on the track put me at a slight disadvantage ( aided by my inability to drive the car without drifting ) Hehehe
Cheers
Ken
paul was probably drinking all his crownies and fighting with the local folk
Nope , most of pwpt60secfalg crownies are in my fridge.
We all came back from the restaurant together.
Guess again
:sperm:
Cheers
Ken
Originally posted by Kyles
ahh so paul and niz.. 'enjoyed' themselves this weekend huh ken!
Yep , they seemed to have a good time watching the action ( on the track ).
I'm sure they will fill you in on the details later.
Bye
Ken
