  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hi Zanda!
So was I Niz! There is 3 people in particular that I really enjoyed shoving it up there butts! They are really snobby and think no-one can beat them, and they were all there watching themselves in defeat!
yeah it took me precisely 5mins to read back thru on 3 days worth! no one said anything i have to kick their butt for which was lucky :P
Aghh snobs - yeah i like to do the same Bayley but i use my car instead of a horse to bring them down to size :D
yeah i usually get the middle age guys trying to show off to their young kids - haha its a case of - sorry but your father is an idiot and about to get chopped. Most young guys dont race me tho - except asians in ricey civics!
Glad double demerits is over with everyone? going to take my Zed out for a thrash soon :D as long as it aint wet cos it'll become my coffin
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
