  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Troy said you christened it, even sent me some pics:p
See'ya:burnout:
Hmmm watch the blackmail pwpt60secfalg , I have a pic that may be worth something
Cheers
Ken:D
