  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
hehe thanks Ken for the great weekend :)
aghhh embassy's n frickin visa's! I give up! :D
No problem , have to do it again sometime.
This time we will leave the ultimate whore behind. :)
Cheers
Ken
Sneeza - i chucked the same tanty last year and went to Queensland - think overseas would be mroe exciting tho - but i partied it up, cleared my head came back home to a clean slate - ad to find myself a new job etc - its really good for u - should do it :D
Originally posted by GTS-t VSPEC
Ken,
What did you do to Niz on the weekend?, she seemed to have a good time:p
Hi Greg.
See'ya:burnout:
Made her laugh and didn't try to molest her:D
Why , what did you do.......
Cheers
Ken
