Originally posted by Sneeza
Ken - checked out the series II - it two pages back what i wroite about it if you feel like reading it...
Yep that's cool , already read it ( I read everything ! ).
As paul said , if it doesn't push your buttons , no problem.
If your planning on going to UK , why buy an expensive car that you will still be paying off when you go ??
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
You didn't try? Why not?
See'ya:burnout:
I like to keep some mystery about me.
As opposed to trying it on so everyone knows what an old perv I really am.:D
Cheers
Ken
Ken - yes I have been through this with about 15 billion poeple! hahahaha I can still have a car - and I will sell it if i go
Trouble is Liz , you will do a bit of money doing it that way.
Buying retail and with a loan is a good way of wasting a few grand.
But hey, if that's what you want , far be it for me to dissuade you.
If I listened to my parents , I would own a holden , have 2.3kids and be a book keeper.
Cheers
Ken
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
