  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh the mods gave up the battle. Seem someone hired a hero from an opposing army. They called him nosferatu Pwptf. in the face of this overwhelming evil the mods had to fall back into the shadows and lie in wait for the day when they could again reign supreme.
Matt dont worry about it - everyone has a bitch - just thought i would do my womanly duty and act shocked thats all :D
Hahah at Boostzor - u lost the battle when Joe came on board :D He was our Trojan Horse!
Had a VL and it was the only car that has never broken down on the side of the road on me and I say that seriously. The GTS-X boiled and was put on a truck home, the red 31 broke 3 times, the Corolla has been towed home 4 times and the VN will only be a matter of time!
Nah, no neon lights yet!!! LOL! Its real flash ay!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
