  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
Nah Kenny not my doing, maybe the chinese guys who took a keen eye to my bits when i drove her in
(please disipher yourself)
Where's the panel work being done ?
Cheers
Ken
Originally posted by Kyles
Yes well if i was 40 i sopose there could be a few to perve on.. but ive got along way to go untill then!!!
Nope , your there already.
Ohh you mean AGE ...
Sorry:D
Cheers
Ken
Oh yeah... When i went to get the 30th off work that friday mondays a public holiday .. yay more time in albany!
Monday is a public holiday ?? what for ??
Cheers
Ken
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
