  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
Nah Kenny not my doing, maybe the chinese guys who took a keen eye to my bits when i drove her in
(please disipher yourself)
Where's the panel work being done ?
Cheers
Ken
Originally posted by Kyles
Yes well if i was 40 i sopose there could be a few to perve on.. but ive got along way to go untill then!!!
Nope , your there already.
Ohh you mean AGE ...
Sorry:D
Cheers
Ken
Oh yeah... When i went to get the 30th off work that friday mondays a public holiday .. yay more time in albany!
Monday is a public holiday ?? what for ??
Cheers
Ken
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
