neo - round 4:30ish... u gonna come up for a sticky beak?
bambam - not too much.. cusco catch can kit, autoguage boost guage and ricey fake matching apex gearnob (with light!) and handbrake metal things... hehehe :P
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
If its anything like Manjimups reaction to WRX's - they will bow down and kiss the ground it runs over and then try and grope the cars - i swear those people never saw a rex til we took one down there - they oooh'd an ahhhh'd and acted like it was a ferrari!
bambam.. nah - i've always been a closet ricey boy.. :P
paul - 243hp.. but i still can't work out how they had it not pinging at that figure - unless they forgot to turn on the boost controller and ran it at stock boost.. but i think that was at about 12 psi so i'm confused...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
