traction is already an issue.. tho i'm thinking that has alot to do with the quality of tyres i'm running...
more power doesn't necessarily mean quicker 1/4 mile times.. but having less power means less go get em from 100km/hr.. :P
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul/aidwin - yea i know thats a high price.. i saw a kit from over east on an r33 on monday when i picked up my car - looked good but the piping was so loose it wasn't funny... and i'm not so keen on the pipe running above the fan... it'd heat everything back up again...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
