Guest 87vlt
Originally posted by Boostzor
Yep sounds like u need to get a girl there Vspec. I met this great girl called Marie Jane she keeps you calm when your in the car and stops you from speeding too. Even  makes big brother watchable :bwhaha:
stops you from speeding or just causes you to drive at like 15kmh even though you think your doing like 110kmh .....
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeh i was saying that prescriptions arent much better then illicit. They still work on the same principal and just casue u got them off a guy in white coat dont make them any better. Behaviour modifing drugs are more often then not used as a quick fix when really the solution is with the individual.
Sorry i like this subject alot:D
i know a few ppl on all sorts of prescription stuff and in most cases they take a turn for the worse.
Well i wont deny my driving needs improvement - mainly cos i live in la-la land but thats only because im going so slow i put myself to sleep. Once the foots down i reckon my drivings fine :D
Yeh big brother definately requires at least 4 pints before it get interesting. What was wrong with seinfeld? they could repeat the same ep over and over and id still watch it.
Just goes to show how many morons there are in the world huh
Yes i can also say that i think a lot of prescription is on the same level if not worse. Some people don thave a choice in their lifestyle - they just kind of get dragged into it - good on the ones that drag themselves out again :D
Oh yeah i run people off the road alright haha mmmmmm bullbar = instant power trip! But these were vehicles that were going to be sent up to the mines - i dont think they should be used for taking bob & jane to school every morning!!
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
