  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Guest 87vlt
Originally posted by GTS-t VSPEC
Nah, she's not colour blind, just doesn't pay enough attention to the road when she has a moron chatting in her ear:D
See'ya:burnout:
that just goes to show she drives to sedately ..... most of my passengers are too busy holding on for life to start a conversation ..... the most I get is "holy shit" ..... j/k .....
Bwahaha yeh page ownage is dumb. It varies depending on your resolution etc so its pointless. No i never have and never will.
If i do change posts its only because soemone has been waaaayyy out of line.
its very rare i will actaully mod anything because ppl keep themselves in line and i shouldnt have to, which is just a testament to the ppl on here.
Guest 87vlt
your a good role model mod ..... keep up the good stuff .....
Guest 87vlt
Hehe, yeah, but I've been warned a few times, I try and control myself now:D
See'ya:burnout:
meh, warned a few times ..... thats nothing I've been ban a few times .... lol .... but I've changed my posting habits now. I did a page ownage before to see what it would be like and god damn is it lame ...... why the hell did we use to do them?
Joes just a whinger - none of my friends complain - well Mel does occasionally til she got her license and now shes worse than me!
I dont know what the specs are on it but theres stuff in there about Cortinas and crap - and i kinda skimmed thru and went hmmm whatever! I dont think the boy knows the front end of a car from a backend anyway. If i start giving him technical info he's going to go what tha?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
