  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Its not really that long. Come to think of it ive never had a b/f that lived closer than 1/2 an hour away from me. It takes troy about 50 min to get here.. thats not that bad.
I moved here because i work in kinross and my mum lives in kinross, and i like joondlaup, other option is the hills where all my friends are or freo where my best friend is.. no way am i living to rocko. I love it around this part of perth.
Originally posted by Neo
Gday Ken
Been working hard? Hope you are doing the dishes alot to get those points up?
Nope , watching some stuff we taped ( Frost , White collar blue ) with the missus.
Brownie points with out work, smart eh ?!
Cheers
Ken
