  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
spike just got his head cought in one of his toys.
Oh guess what the little bugger did today. He was sitting just below my neck next second his heads in my cleavage and hes chewing on my bra.. i lost it laughing.. I dont think troy was impressed.. he grunted when i told him.
Ohh lucky , lucky bird.
* now wheres that weiro gone *
Spike replies
* Help , help , i'm going under *
Cheers
Ken
Originally posted by Neo
Ken
Can you recommend anyone for a front/dump fabrication. Would like to keep it tidy??
paul would be the one to ask.
I use Butler exhaust or Exhaust dynamics but the are NOT cheap.
Cheers
Ken
JOE what are you still doing here.. gez this girl will dry up and go home before you get to her.. or she will do the job herself.. get in there boy!!
or was that puncture and blow out the window ??
Cheers
Ken
Originally posted by caminperth
hey guys.. hows things.. me just had some fun at kwinana.. unfortunately it's going to cost me a new clutch.. doh!!
And another ones gone , another ones gone , another one bites the dust...
Cheers
Ken
neo - 1st run me driving car did it's best.. 13.63 @ 163km/hr
2nd run my dad had a go - got excited and cooked the clutch..
I did two more runs - both 13.7.. way home clutch was slipping badly.. 1/4 throttle in 5th gear = lotsa revs - no go... :(
looks like my new clutch is going to happen way quicker than I thought...
or did you have the same problem that guy off america pie had with the exchange student in his room had??
was that the one where he gave her a lovebite , she farted in his face and blew out the window ?
or maybe not:D
Cheers
Ken
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
