  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
neo - not on the first run.. things got a bit hot by the last one so it was pinging a little.. but to it's credit i was running 0.9bar!
as for the blame it on dad - the clutch was pretty hammered by me beforehand over the last year.. he just cooked it for the final time...
Originally posted by Kyles
what american pie did you watch??
The scene where hes on the bed sitting next to the girl and goes to touch her and blows himself.. a few times..
Watch ... ?
I was talking from experience.j/k
Cheers
Ken
Originally posted by caminperth
ken - drag racing is good - u just have to not get excited at the launch.. :(
hmmm , the more money you spend the quicker you are and the less time on the track.
Yep , that sounds like fun...
Cheers
Ken
Originally posted by Micko
Where are you boing for a new crutch cam?
Ross @ Autoclutch seems to be the go:thumbsup:
not sure.. am going to check it out tomorrow if work allows it.. ie - me not too busy... good thing is i don't have to drive to work so it can rest for a while...
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
