Originally posted by Neo
Nite Kyles
Shit i feel like shit they have a farewell to Possum on sports tonight. What????? no no.
Yea Deans going to the funeral in NZ on Tuesday and then back to Sydney for some memorial thing on Friday.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by caminperth
ken - you got me there.. :(
car isn't going to be directed to a drag only car.. is a good measure of mods tho i think...
Why , track cond , tyre cond , ratio of diff phases of the moon all affect your times.
Unless you are there at the same time as the other guys , it's comparing apples and oranges.
Cheers
Ken
Originally posted by Micko
Ken - does anyone know the truth about the accident yet? There has been a lot of speculation...
My version from a reasonable source is that Poss was coming back down the hill from his recce run for a news media thing and was a little late.
Convoy of cars were going up doing there recce run and Poss got the last car ( a Jeep ).
He was in a Forrester and the impact was rhf , drivers door area.
The road was supposedly open to the public so in theory speeds were slow. yea , right.
Cheers
Ken
You are all late nighters but late morningers as well ay? Well, good morning everyone! Who was at the drags last night? There was about 10 Skylines. I liked the black 32. Oh, and the red R31, it had RS Turbo on the side so yeah!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
