  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
yeah im sure there is - hope they are dealt with - but they shouldnt just be let go out of the count theres people doing worse stuff - if they think they can get away with that then they'll try their luck doing more seedy stuff. Its a case of they agreed to play by the rules when they entered the force - like any other place of employment - if they cant abide by the rules they get sacked.
there's nothing in their code of conduct that says they shalt live a life unto chastity and the good grace of Darwin.
Originally posted by GTS-t VSPEC
Alex,
Yeah, his cars quite quick now, we had a race down the freeway, only up to 100 though *cough*
See'ya:burnout:
yeah. not any more. His old man MELTED his clutch. MELTED!!
I could still smell it when we were driving down the freeway on the way home.
Im not really surpised. I would have said that his car is about half a second quicker than mine. plus a little bit for driver noobiness. seems about right.
so who got to 100 first?
There is always an upside Niz.
All i need to do is go sit in a park on a windy day or go for a drive at night to realise how great the world is. I love the feeling of insignificance means i can determine my own path.:mad:
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
