yeah but surely u can tell! If he carries thru he will get stung - the people around here aint that stupid - wouldnt of taken him seriously if i didnt see the cake haha. Dont think he cares if he gets caught and loses his job.
oh well today should b interesting - hopefully my supervisor is in that meeting :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ohh so what about other SAU dudes? just a one day trip down there?
and paul, the cam gear payment is all sorted, gonna head down to nandos soonish to fax the net banking receipt to brent then all should be good and the goods will be on their way :)
adrian :D
adrian - how are ya bud.. hoep things are goin well - i hear ur doin a few mods.. can't wait to have a look-see..
paul - thanks, am going to ring the insurance place in a second.. will hopefully get it replaced this arvo...
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
