  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
inlight of lauren and my pending birthdays i thought this appropiate though it relates more to me seeing i'm an old fart.
Ageing
God grant me the senility to forget the people I never liked anyway, the
good fortune to run into the ones I do, and the eyesight to tell the
difference.
Now that I'm 'older' (but refuse to grow up), here's what I've discovered:
1. I started out with nothing, and I still have most of it.
2. My wild oats have turned into prunes and All Bran.
3. I finally got my head together; now my body is falling apart.
4. Funny, I don't remember being absent minded...
5. All reports are in; life is now officially unfair.
6. If all is not lost, where is it?
7. It is easier to get older than it is to get wiser.
8. Some days you're the dog; some days you're the hydrant.
9. I wish the buck stopped here; I sure could use a few...
10. Kids in the back seat cause accidents.
11. Accidents in the back seat cause kids.
12. It's hard to make a comeback when you haven't been anywhere.
13. The only time the world beats a path to your door is when you're in the
bathroom.
14. If God wanted me to touch my toes, he would have put them on my knees.
15. When I'm finally holding all the cards, why does everyone decide to play
chess?
16. It's not hard to meet expenses... they're everywhere.
17. The only difference between a rut and a grave is the depth.
18. These days, I spend a lot of time thinking about the hereafter . I go
somewhere to get something and then wonder what I'm here after.
19. I AM UNABLE TO REMEMBER IF I HAVE MAILED THIS TO YOU OR NOT!
20. Funny, I don't remember being, . . . absent minded...
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
