Originally posted by Pva_Glue
Tanya and friends going to Freo to meet some yankee sailers... :P
I think most of chicks are heading there tonight...
poor joe
i thought and her were through anyways??
put it this way joe, she can get treated well, have heaps spent on her drinks food etc, and if she plays her cards right could end up with afew hundred US$ if shes good at pool or something else
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
geez joe - yankee sailors - got yourself a quality one there! Hmm joe might want to look for someone else - cmon i mean yankee sailors?
No im really looking forward to my birthday :P should be a great party.
Dont worry about me im just a bit wrathful at the moment.
Hmm not too bad but very slow.
I think im going round to an accountant friends house. Hes cool but not ultra exciting. I have a feelign that ppl will end up playing risk and watching footy.
I finsh at 5 and then i go get my engine mounts......mmm polyurethane.
So Niz i knowiim not supposed to ask but what should i get ya? anyhting uve been wanting?
Ahh poly is just more durable. Polyurethane is a actaully calssed as a lquid so it moulds to its surroundings nicely while rubber will just bend and stuff and hold its shape.
ill have to get u a few drinks at the least.:P
all i ask is for nothing to get broken haha - otherwise i wont reach my 21st!
ooooo technology :P hehe
my cars getting serviced and tuned on Tuesday :D hopefully my rough idling will be no longer!
haha i dont mind if people misbehave (ill be the ring leader) - just for the love of god dont break anything - a lot will be put away anyway cos my folks place has a lot of knick knacks
Tell Gradenko not to be unsociable and come geeez!!!
