  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ahh i'll go to xspeed, for the peace of mind that they'lldo a goodjob! anyways i am off boyz catcha later hopefully by tonight i can have my screamer pipe on, and yall can come check it out :P hehehehe as i got the next two days off :P heheh the peeps at work reckon i deserve a break :(
adrian :P
yeah im trying everything Paul - hmmm computer let me into chatrooms but not accomodation sites - go figure! Found htis one place mmmmm heaven but at $180 a night minium two nights stay it would want to be!! oh well when i win lotto :P
Originally posted by GTS-t VSPEC
Bayley, I was pissed off cause of the yellow sticker, so I took my aggression out:D
See'ya:burnout:
We were sitting there and then heard it and Jeff goes, that was Paul!!! I was like, what did he get a yellow for, bald tyres? What did you get it for?:shake:
oh u should see the furniture in it and spa and just everything its totally gorgeous - thing is id get there and never want to leave. pity one night.
shall keep searching..... when i can anyway!
I'm with you paul....had some pig attention last night..
minding my business pulling out of Dewsons shopping centre around 8:30pm (yes, it's open till 9pm) up the road, doing like under 50km/h (was having a conversation with the gf next to me)
coppers were stopped on the side of the road in thier paddy wagon, as soon as I passed them they started driving and followed me.
going thru a few roundabouts, sticking to limit i was fine, then i thought, nope. i'm sick of them tailling me so I pulled into the next service station and parked the car to get some munchies...
they followed me right up into the servo and watched me get out of the car and go inside.....
... i was pissed off! then they left.. there was NO call for them to be assholes... but no no, let's follow the IMPORT DRIVER and ignore the rattly shitbox that was next to me!!
ive only been tailed by a copper once - on a test drive of a skyline - otherwise its usually me tailing them :P
Im lucky that my rare brushes of law have been pleasant ones - prefer it to a multinova anyway - as one copper told me "im not a multinova so he began to bargin with me hehe"
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
