  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
i can tell u what happens
wolverine and rogue get nasty in the x-man jet
storm bends jean grey over the operating table
mystique morphs into a dildo and pleasures herself
lol
believe???
Man I hope so!
