  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
which is why I can't work out why people try to make their GTST's into R copies or try to make them faster.
My saying is that if you want a faster car , buy one from the manufacturer. Usually works out cheaper in the long run.
Cheers
Ken
Originally posted by caminperth
ken - yea.. well maybe half of it is in my head - but i honestly think it has made a diff.... u don't think they are worth it?
I assume you are talking about the brace between the shock mounts under the bonnet and not the sway bars under the car.
Strut braces work if they are attached to the suspension ( ie Macpherson strut style. )
The lines are double wishbone and the mount you are attaching to is not a stressed member of the car.Also unless it is straight and substantially thick , it will flex anyway.
I think you would find if you did an MC type day with the bar on and off , the difference would be marginal.
But hey , it looks cool and I have em on my car ( cos they came with it )
Cheers
Ken
Cheers
Ken
ken - hmmm everything you say sounds right.. but it still seemed to make a difference... maybe it is all in my head... but as you said - they look cool.. hehehe :(
paul - springs will be on the cards definitely.. was talking to no_respect tonight when i picked up the brace - his is about the right height (only about an inch lower than mine) and he said that he still retained a firm but comfy ride... he also said they're pretty damn easy to fit?
Originally posted by rob77
Ken, any pics or details of mods at all?
Ahh let me think
ARC aircleaner box
Big gay ally wing
18x9 BBS
Momo wheel
Recaro drivers seat
1/2 cage ( not in atm )
cusco shocks all round
Nismo top and bottom rear arms
Nismo caster arms
HKS evc4
4 defi gauges
cusco 1.5 way super f**cking loud diff
ogura twin or triple super f**ing bitey clutch
Got some pics of the as arrived condition but need your email addy.
Cheers
Ken
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
