  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
ken they refused my loan the bastards.
So i couldnt get it. Not a hudge deal.. there are busses, pitty they are crap.
I went to catch a bus from work at 6 pm, and it was 40 min late, So i ended up walking down to the train station and back tracked home to see the buss that i was waiting for drive past 40 mintues after it should have been at the stop in kinross.. shocking. And today it was 25 min late, I started walking but when i got to the next stop it came around the cnr, i was just past the buss stop so i stood in the middle of the road to make sure the bastard stopped...
i went for an 800 buck loan for a computer the pther day and got rejected. so im stuck with this pos. i got told they will send me a letter telling me why. i got the letter and all it said was. "you may have been rejected for one of the following reasons" it also stated that they had carefully considered my application. it was a internet jobbie at harvey norman. and it took all of 15 seconds to get a reply back
Psiker
yeah sure none of us know everything but at least we know whether our cars a GTST or not - not just say oh its got a GT badge on the side :P i think it pays to know at least the MODEL of your car for phucks sake!
Talking abotu knowing nothing - i want to play with my bleed valve n up the boost but i dont know how much i can play with it before the cars goes BOOM hehe
Thats the funny thing though. I went for an agc credit card at harvey norman and they gave me $2500 limit ... what the???
and they wouldnt give me a 6.5 grand loan. Oh well atleast the agc card will give me a good credit rating so i should get a loan after i pay of the new washing machine, couch, and floor rug
Originally posted by Sneeza
yeah the car i am talking about was in for $17900 and then he just messaged me saying that he will give it to me for $14000...... whatever
Whast an idiot. You told him you wanted a turbo so why would you give him ANY money for it .
Cheers
Ken
hehe u should ask Hicks, Strich9 or my bro how much u can up ur boost b4 u do ur coola pipes. my bro was running bout 13psi when he did his. its now back down to about 11-12psi (this is in a 180)
Psiker
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
