  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I've changed my home loan from a std 25 year mortgage to a offset/equity loan. I bought the house 2.8years ago for $85,000 its now been valued by the bank at $110,000. I've got the loan down to $70,000 by paying a bit extra each fortnight for the lasy 2.8years, so I've taken a low offset/equity loan at $82,000. So I've got a bit of extra cash lying around incase I need it, but cos its an offset loan I should pay it off much quicker than the std 25 year loan. Its a bit confusing but I sat down and did the figures, going as I was the 25 year loan would be paid off in another 12 years with the new offset loan it'll be closer to 3-5 years depending on how frugal I am, quicker if my wife gets another job too :( Stupid education dept wont give her a job in the metro area :P So yeah, we want some french doors to open out onto our courtyard and I want to do more work on the car :)
Powerfc will set me back around $1700 delivered new with controller, then plus fitting and tuning. The autronics is $3500 drive in and out, but has boost control built in (if I want to sell the blitz sbc will make the install cheaper), traction control, serial port connection to a laptop with easy to use PC software so I can **** with maps when I know what I'm doing.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
