  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
wats up? soooooooooo me happy now i realise why people get all happy after installing a dump :) instant power and response gain, anyways i am gonna be ordering my intercooler soonish :) brent reckons he can lower prices if i can get another group buy happening :D
adrian :(
kits buddy nuthing but kits :)
well he reckons he is slashing his prices for the hks cooler kit to $1300 also the trust kit for this price :D but if i get another group buy happening he will drop prices even lower! how good is that :(
adrian :)
hey Adrian, hows the new dump / screamer? :)
hehe 1300? thats damn cheap, is he making any money on these at all? lol thats like cost price, depends what model tho...
anyway get more info cause im on the search for an intercooler now too:)
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
