  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Hehe, well you should have rethought that pic that you took last time:p
See'ya:burnout:
Is she STILL pissed off about that ??
I can post it up so she can delete it. lol
Cheers
Ken
Oh how's this - pwptf & ken - what an occasion!
Ken - tech time:D
Been thinking about a 2wd/4wd switch. What if I connected a switch to the fuse under the dash that controls the 4wd & abs - flicking th switch is just like pulling the fuse - no more 4wd - great for circle work, etc
Ken - tech time:D
yep should work . I got the one that plugs into the G Sensor under the console.
Circle work is good in 4wd though.Makes you damn near pass out with the G force.
Cheers
Ken
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
